Window Behavior on Closing
Postby B2B_Investing » Mon Jul 27, 2015 7:07 am
I am not sure if I am doing something wrong. I generally keep a few windows open all of the time, even when I close FM. (The portfolio editor window, a performance graph of the of the portfolio and two portfolio performance reports). Two things that happen that inconsistantly happen (in the Personal Version if that matters) are:
1. Upon reopening the windows will all be minimized in the top right corner
2. The Portfolio Performance reports will reset the column spacing to the default, even spacing. The default spacing will cut off the security name and sometimes truncate the %yield column. It seems a bit odd that the I need to resize both the columns and the window
It does not happen all of the time. I am not sure why it does, but wanted to pass it along.
Jason
B2B_Investing
Postby Mark » Mon Jul 27, 2015 11:29 am
Hi Jason,
The next time it happens, if you can create a backup file, we can try to reproduce the problem here. Right after it happens, use "File / Backup..." and email us that *.FMB file.
