Win10 Upgrade user
Postby clivusmul » Mon Aug 03, 2015 3:02 pm
I upgraded to Windows 10. I can not autosave my portfolio upon exit. Message is "Access is Denied..." ; then "Autosave failed..."
I have read previous discussions on the Access is Denied topic on this forum and have used the File Operations location assignment successfully, etc. The only way I can save files is to start the FM program using Start as Administrator... Funny thing is that I am the Administrator. I also checked the file properties for all files in my Users/Owner/Fund Manager folder and they are all set for full access... What's wrong?
Another quick... I have the program installed on my Desktop and my Laptop. The Desktop is fine... It was updated the same way as the Laptop... The difference is the Desktop has a different name for the User folders. I did a restore of the Desktop file and stored the new portfolio to the correct folder on the Laptop... Still get the Access denied message... Help.. Bob
clivusmul
Postby Mark » Mon Aug 03, 2015 3:04 pm
Hi Bob,
Did you check the properties of the file that is failing to save? If it is your *.mm4 file, check that, or if it is a particular investment file (*.dat), check that. Make sure it isn't marked as Read-Only, and that your user has edit permissions for the file.
Postby clivusmul » Mon Aug 03, 2015 4:21 pm
I think it was the read/write privileges on the "name.MD4" file. On my desktop system, the "read only" button is activated but on the Laptop where I had restored the desktop file TO, it was not highlighted... So, I went into the Security tab and dropped to the "HomeUsers" group and set the Permissions to allow everything. That cured the problem and now I can write to the folder and autosave the program.
Interestingly, if I now go back to look at the file permissions, the group policy has 3 of the 5 permissions set but the "everything" is not as I had saved it BUT the "read-only" button on the General Tab is highlighted whereas before it was not highlighted... Seems the permissions I gave this file on the security tab may conflict with other permissions in general but getting the "Read-only (Only applies to files in folder)" button activated seems to be the solution..
Thanks for pointing me in the proper direction. Bobj
clivusmul
Postby clivusmul » Mon Aug 03, 2015 4:23 pm
Mark, my bad... Should have been .MM4 file NOT ".MD4" sorry. bj
clivusmul
