New Portfolio Setup Wizard
Postby TheAlgorithm » Mon Aug 03, 2015 7:22 pm
When I open the program, the new portfolio setup wizard pops up even though I already set up a portfolio. I then cancel out of it, and go to File/Open Portfolio and click on Liquid.mm4 and I get back to the portfolio I previously created. However, this wasn't always happening. The first couple times I used it, the program would know to just go to the portfolio I had created as soon as I opened the program and it didn't send me to the new portfolio setup wizard. Why is this happening and anyway to get back to how it was before so that the portfolio opens on its own when I start the program?
Tarak
TheAlgorithm
Postby Mark » Mon Aug 03, 2015 7:30 pm
Hi Tarak,
Is this option, turned on:
Options / General Preferences... / Data / Open Last Portfolio at Startup
Make sure that is turned on. Also, are you getting any errors when you exit Fund Manager?
Postby TheAlgorithm » Wed Aug 05, 2015 7:19 pm
That option is checked, and I get no errors when I shutdown. For some reason it started working again though. Not sure what changed. Thanks.
TheAlgorithm
