using Mod 480 & Win 10 -- can't retrieve stock prices
• Page 1 of 2 • 1, 2
I got module 480 and am using Windows 10. I click on the PRC button to "retrieve - internet (yahoo)" and get the error message, "Could not update any investments." Please advise.
Hi suebrooks39887,
Are you using Fund Manager 2014.13.7? See "Help / About...". Do you have some investments open that are marked for retrieving, and have valid symbols as shown on Yahoo? Right mouse click on an open investment and choose "Properties...". Verify the symbol is correct, and available on the quote server you're using. Also, look at the "Internet Retrieve" tab, and make sure "Retrieve Price" is checked. For more tips, see: https://www.fundmanagersoftware.com/faq ... ailure.php If you're still having troubles updating, please let me know a sample ticker symbol that won't update.
Yes, using 2014.13.7, module 480.
Under Internet Retrieve Setting, Price Update Options: Default server: Yahoo Default history server: yahoo persistent request - checked proxy server - checked Prices (ex: aapl) were downloading last week, until I downloaded Windows 10 yesterday (Sunday).
investment properties -- for aapl
internet retrieve retrieve price -- checked quote server: "default server" historical server: "default server" I changed the quote server to yahoo and the historical server to yahoo for aapl, and the price did not download.
You said proxy server was checked. Do you mean the option to "Use Windows Settings" is checked?
If you choose "Help / FM on the Web / Check for Updates...", does that work okay?
Under Retrieve Settings:
Proxy Server: Use Windows Settings -- checked (Connect with proxy server is NOT checked) Under Help, FM on Web, Check for Updates, Internet Quote/Pager Server Status: Currently using Quote Module version 480, latest available is 480. Currently using Transaction Retrieve Module version 200, latest available is 200. FUND MANAGER QUOTE SERVER STATUS Last updated June 3, 2015: The latest version of Fund Manager 2014 is: 2014.13.7. Quote Module: 480 Transaction Module: 200
Okay, please try this:
Delete all the intlog*.txt files in your folder: C:\Users\<username>\AppData\Roaming\Fund Manager Right mouse click on AAPL, and choose "Retrieve Selected Price". Assuming it fails with the same error message, please email me all the intlog*.txt files as an attachment to an email. I will send you an email now, so you can reply to that with the attached files.
I'm not finding any intlog*.txt files. I searched the whole computer for intlog* and for *.txt. How do I find it?
I attempted to retrieve selected price for aapl and "could not update"
Instead of searching, just use the File Explorer, and browse to this location:
C:\Users\<username>\AppData\Roaming\Fund Manager Please note, the "AppData" folder is hidden, so you'll have to turn on the display of hidden items. In Windows 10 there is an option on the toolbar for this.
Hi suebrooks39887,
Received the log files, thanks. Somehow FM is getting back an error message from Yahoo, saying the request was invalid. I don't see that same problem here, so I'm not sure what is wrong. I would suggest re-installing Fund Manager, and if that doesn't fix it, please give us a call. We can connect into your computer, and try and diagnose the problem.
Do I use the "buy now" link and use my key?
No, you don't have to buy anything. Just go here:
https://www.fundmanagersoftware.com/download.html and download/install the program. Install it right over your current installation. Do not uninstall your current program.
Hi suebrooks39887,
It looks like this may be a problem with Yahoo, and not related to being under Windows 10. See: viewtopic.php?f=3&t=3590 You might try that solution, or wait for a while for Yahoo to resolve the problem, or switch to a different quote server.
I just retrieved using Reuters. Took longer but it worked.
Who is onlineUsers browsing this forum: No registered users and 7 guests |
