mobile data
Postby alpappy » Thu Oct 01, 2015 5:09 pm
HI the control F2 is not active greyed out Also on exit the mobile data is not being updated
thanks
alan
alpappy
Postby Mark » Thu Oct 01, 2015 5:13 pm
Hi alan,
Did you set up your account okay? Go to "Options / Mobile/Web Access / Account Settings..." and make sure you enter a username and password and then press OK. Make sure you do this while you are in the portfolio file that you want to upload.
Postby alpappy » Fri Oct 02, 2015 12:47 am
HI account set up fine first upload perfect now does not work Option greyed out onmenu
auto uploads and close upload no longer work am using windows 10
alpappy
Postby Mark » Fri Oct 02, 2015 8:57 am
Hi alpappy,
What happens if you go to "Options / Mobile/Web Access / Account Settings..." and make sure your username/password are entered, and then press OK. What message do you get after pressing OK?
Postby alpappy » Fri Oct 02, 2015 1:30 pm
HI yes worked that time looged in and asked to update all good now
Would think it is Ok to upgrade fully to the beta now ..else when will you release it as an alpha
thanks
alan
alpappy
Postby Mark » Fri Oct 02, 2015 1:59 pm
Hi Alan,
Glad it is working.
You can't buy the 2016 license yet, but I expect the official release to happen in the very near future, and then you will be able to. Until then you can just use the Beta 2016 version.
