Using a VPN connection is slow
Postby mecrews » Mon Dec 21, 2015 12:29 pm
When opening Fund Manager using a network drive via VPN -- the data takes a longtime to load. It could take 5+ minutes to finally open the portfolio.
My question is this normal and is there anyway to speed this up if not? Often I need to work from home and access the data from a laptop with a vpn connection to the office network.
Thanks!
MC
mecrews
Postby Mark » Mon Dec 21, 2015 2:58 pm
Hi MC,
Fund Manager doesn't do anything special when going over a VPN. When you open a portfolio file (*.mm4), all your investment files (*.dat) are also read. If your connection to the data files is slower, then the opening process will be slower. The only "fix" is to move the location of your data files, so you can access them faster, like from the local disk.
Postby mecrews » Mon Dec 21, 2015 3:04 pm
Thanks for the reply. I figured as much -- I think it's just the volume of .dat files that is the problem when running it over an internet versus an intranet.
Again -- thanks for the quick response.
MC
mecrews
