Version 9 Installation Errors
Postby gmfry » Fri Aug 22, 2008 2:33 pm
During installation of version 9, I received several error dialogs concerning .dat files in the Samples folder. They all read:
"Error opening file for writing:
\FundManager\Samples\dji.dat (the file changed for each error)
Click Abort to stop the installation,
Retry to try again, or
Ignore to skip this file."
I clicked on "Ignore" for each in order to continue the installation. Fund Manager seems to work OK without these files. Do I need to do anything else?
Gerry
gmfry
Postby Mark » Fri Aug 22, 2008 3:32 pm
Hi Gerry,
It sounds like some of your sample files may have been marked as "read-only". You could check this, and remove that property, and then re-install. If it was only items in the sample folder, you can ignore this, as you don't need the samples for normal operation.
