Hello,
My installed version is 2016.14.0.100. The updating process to ver. 2016.14.4 looks okay, but when I check program is not updated. I repeated the process several times - without luck....
nebfinfm
FM2016 - unable to update to ver 2016.14.4
Hi nebfinfm,
Did you download and run the setup program for the new version? Just go here: https://www.fundmanagersoftware.com/download.html and click the blue "Download" button for your version. You need to run that downloaded file. You may be prompted for permission by Windows to make changes. You should see the option to "Agree" to the license terms, and then click "Install". Once you're done start up Fund Manager under "Start / All Programs / Fund Manager / Fund Manager". Check under "Help / About..." and you should have the current version (2016.14.5).
Hi nebfinfm,
What problem are you running into? Do you get some error message? The general process is that you visit our "Download" page, and download and then run the setup program. After that, start the program under "Start / All Programs / Fund Manager / Fund Manager".
It sounds like you may have the program installed in multiple locations. I'm guessing the old shortcut in your taskbar was pointing to the old installation. The shortcut under "Start / All Programs / Fund Manager" is created/updated when you install Fund Manager, so that is a good way to start it. You can make your own shortcut, or a copy, but just check the properties to make sure it is pointing to the current installation.
Who is onlineUsers browsing this forum: No registered users and 14 guests |
