Configuration:
Win 10 v1511 build 10586.71 (64 bit)
FM 2016.14.5.100, QM 493, TM 215
Problem demonstration:
Select Master Portfolio
Select retrieve and update prices from internet (YAHOO)
Price retrieval completes without reporting errors.
Save investments.
Inspect investment files (.dat) in win explorer. All investments files have date modified as today, except two files not updated.
Right click one of two investments that was not updated in FM Portfolio Editor, select Retrieve Internet. Returns error "Could not update any investments."
Click OK and view internet retrieve log file, last 2 lines: "Could not update any investments.
WARNING: Server used but did not update any prices: (YAHOO)"
Right click same investment ->retrieve historical (last 3 days). Same error. Reviewing log file shows that correct investment data was retrieved from YAHOO server but not saved.
From FM PE ->properties-> statistics File size and filename path match the expected file path. (both files)
FM PE double click selected investment (F5) -> Prices -> new enter the price from YAHOO manually. Click OK. Save Investments. Then the file modification date is updated to current date and price in FM is correctly edited.
Conclusion? PE can update the investment file but the QM cannot ??
More investigation:
Further inspection shows all files (including the problem files) have "rwx" permissions set for my user name. (Same for all other files that are working OK. everything seems OK from Windows)
Other news:
I typically retrieve prices from the master portfolio, and this group price update does not return any errors. Inspecting the price history for these two problem files I found that this issue has persisted for some time predating the Win 10 installation and fm 2016 last month. (Looks like I was just manually entering the prices quarterly on these investments for a while, and did not think about why until now. )
Not sure where to go with further diagnostics on this issue. Any ideas about what may be wrong?
