Download older versions of Fund Manager - Problem persts
Postby JamseRJ » Wed May 18, 2016 1:21 pm
I neglected to download the last update to the 2014 professional version of Fund Manager, 2014.13.8.
According to the revision history, "Fixed issue where the quote/transaction modules could be incorrectly reported as having a bad digital signature". This is the problem I am having with my latest version, 2014.13.7.
Is there a location where the 2014.13.8 version of the professional version can b downloaded?
I tried https://www.fundmanagersoftware.com/download_old_fm.php location but it does not seem to be working foe me. OK, it did work, I had not the correct information the first time I teed it.
After downloading the 2014.13.8 version of the professional version, and installing it. I tired to update to the Quote Module version 494 and the Transaction Retrieve Module version 218 from the previous versions. Then i get "Quote module is not digitally signed" and "Transaction module is not digitally signed".
James
JamseRJ
Postby Mark » Wed May 18, 2016 1:41 pm
Hi James,
Yes, that is the correct location to get old versions:
You do have to enter your license name/serial exactly on that form to get the older version.
Postby JamseRJ » Wed May 18, 2016 4:04 pm
Please see the edit version of the original post at the end. Still cannot update the quote and transaction modules. Still get " module is not digitally signed" for both when try to use them.
JamseRJ
Postby Mark » Wed May 18, 2016 4:07 pm
Hi JamseRJ,
If you look under "Help / About..." what version does it say you have installed?
Postby JamseRJ » Wed May 18, 2016 4:14 pm
It ssays
Professional vesion 2014.13.7 !!!
How did that happen? I will try to install 2014.13.8 again!!\
James Jenkins
JamseRJ
Postby Mark » Wed May 18, 2016 4:17 pm
Hi James,
Make sure you are running the downloaded setup file. You should see the "I Agree" and "Install" steps in the setup wizard.
Postby JamseRJ » Wed May 18, 2016 4:25 pm
I am running the fmnpro2014p8.exe file I downloaded. I do not see the "I Agree" or the "install" steps. It does not seem to be a zip file with a setup inside it.
JamseRJ
Postby JamseRJ » Wed May 18, 2016 4:37 pm
I was mistaken, the "I Agree" and "Install" steps are there. I ran the install.
I now have version 2014.13.8 in the About box.
I downloaded the module updates and they are working now, both the Quote and the Transaction Retrieve modules.
Thanks for your help and sorry to have to had bother you.
Regards,
Jamrs Jenkins
JamseRJ
