Currencies not updating
Postby alpappy » Thu Jul 14, 2016 3:28 pm
HI Since recent module I cannot get the currency quotes to update Have tried yahoo and Qndl No luck
Also what is the default server now?
Thanks\alan
alpappy
Postby Mark » Thu Jul 14, 2016 3:31 pm
Hi Alan,
You control the default server under "Options / Internet Settings...". What exact quote server and symbol combination are you using that won't update?
Postby alpappy » Thu Jul 14, 2016 3:34 pm
Hi All the internet retrieve in the currency files are now blank Not sure what one I was using proabably bloomberg eg nzdaud:cur
Not sure what to use now Do I need to go over eah position that was using bloomberg and change one at a time?
thanks
alan
alpappy
Postby Mark » Thu Jul 14, 2016 3:42 pm
Hi Alan,
You can get exchange rates from either Quandl or Yahoo. Whichever one you choose you will need to use their symbol. Visit that server's site with your browser, and look up the symbol. We will be updating our FAQ soon for this. If you just need current exchange rates, try Yahoo. If you want to get historical exchange rates, use Quandl.
Postby alpappy » Thu Jul 14, 2016 3:49 pm
Is yahoo working Also would you advise setting the default to yahoo from now on?
Quite a lot of work Pity about bloomberg
Is it worth then upgradint to higher version to get live quotes from yahoo?
thanks
alan
alpappy
Postby Mark » Thu Jul 14, 2016 3:55 pm
Hi Alan,
Yahoo (Historical) is not working at the moment, but Yahoo is. We are working on fixing this. See: viewtopic.php?f=6&t=3926
If you want current exchange rates, use Yahoo. If you want historical exchange rates, use Quandl (Historical).
