New update problems
Postby Alexanderfrood » Thu Jul 14, 2016 11:11 pm
Stops during install. Gives the following message...
Cant write C:\Program files (x86)\Fund Manager\FM.exe
Tried running as administrator but still get the same message.
Alexanderfrood
Postby theobaldr » Fri Jul 15, 2016 4:55 am
Download of update fails to download. Using Firefox. :oops:
theobaldr
Postby Mark » Fri Jul 15, 2016 7:20 am
Hi Alexanderfrood,
This sounds like a permission problem. You do need to be running as an Admin in order to install into the Program Files (x86) folder. You might try re-starting your computer, and then installing it first thing, in case something else had a lock on it. If that doesn't work, you can try manually deleting the files in that folder, and then installing.
Hi theobaldr,
Are you trying to download from here:
https://www.fundmanagersoftware.com/download.html
What specifically happens when you try to download? Do you get any sort of error message? I just tested it, and our server appears to be working okay, and it downloads okay from here.
Postby Alexanderfrood » Fri Jul 15, 2016 7:55 am
Hi Mark
Yes, your suggestion of turn off and then update straight after start-up worked fine.
Alexanderfrood
Postby theobaldr » Sat Jul 16, 2016 8:50 am
Third download after posting my message worked. There were no error messages on the first two, except for download failed.
Ray
theobaldr
