Switching FM between computer and memory stick
Postby nebfinfm » Wed Aug 03, 2016 8:47 am
Normally I'm running FM on computer C: drive and the data are in folder(s) located in Encrypted Data Vault (virtual disc G:drive). When I travel I want to run FM in portable mode installed on a memory stick. I have no problem to copy the Encrypted Data Vault to memory stick and decrypt there. What do I need to do run FM either in portable mode or normal mode? How to sync data?
Thanks nebfinfm
nebfinfm
Postby Mark » Wed Aug 03, 2016 9:00 am
Hi nebfinfm,
You can read the instructions on setting up and using portable mode here:
https://www.fundmanagersoftware.com/help/portable.html
Let me know if you still have any questions.
Postby nebfinfm » Wed Aug 03, 2016 9:33 am
Mark wrote:Hi nebfinfm,
Please tell me the procedure how to install FM into folder on desired portable drive. I have FM already running on C: drive. Thanks nebfinfm
nebfinfm
Postby Mark » Wed Aug 03, 2016 9:37 am
Hi nebfinfm,
Just run the setup program, and when it asks where to install, browse to wherever you'd like to install it. You can get the setup program from the download page:
https://www.fundmanagersoftware.com/download.html
