Hi:
My Windows install has gone bad. I have 8 cores working over 70% doing nothing I can discern.
What should I try to save other than my FM data in the way of settings and custom reports and where is it located.
Scott
Moving to new Windows install
Hi Scott,
If you can open up Fund Manager and view all your data, use "File / Backup..." and save that *.FMB file somewhere safe you can restore from after fixing your system. When you get things fixed, just use "File / Restore..." and pick that *.FMB file you saved. That backup file contains all your data and preferences. If you're using multiple *.mm4 portfolio files, then you'd need to create a backup for each one. Please also see this: https://www.fundmanagersoftware.com/newcomputer.html
Who is onlineUsers browsing this forum: No registered users and 17 guests |
