Display changed
Postby senior » Mon Oct 17, 2016 7:41 am
I clicked on something wrong and since that I get always the portofolio manager displayed instead of the nine graphs that I am accustomed to. Please how can I restore my previous settings?
Best regards,
Peter Petula
senior
Postby Mark » Mon Oct 17, 2016 7:44 am
Hi Peter,
Switch to your graph window by selecting it from the "Windows" menu. If you don't see a graph window listed under the "Windows" menu, then you've closed it. You can re-create it by choosing the graph type you want from the top level "Graphs" menu. After you have your graph window open/displayed the way you want, use "File / Save Portfolio", so it will come back up this same way next time you start.
Postby senior » Mon Oct 17, 2016 8:42 am
thank you for the quick reply.
Peter
senior
