Portolio Editor Missing Totals
Postby 12garyv » Sun Apr 16, 2017 5:54 am
Although I have checked the relevant box under general preferences, my total line has disappeared. Is this a problem with my data file and how do I fix?
12garyv
Postby Mark » Sun Apr 16, 2017 8:20 am
Hi 12garyv,
So, you checked "Options / General Preferences... / Portfolio Editor Display / Show Totals in List View", and you're not seeing the totals line? Is the bottom of the window maybe off your screen? If you use "Window / Tile Across", do you see the total line?
Postby 12garyv » Sun Apr 30, 2017 4:45 am
Thanks, Mark. Everything was on my screen but I grabbed the bottom of the window and pulled down and that solved the problem.
12garyv
