ERROR: Unable to create automatic backup folder
Postby schwarcz » Mon May 15, 2017 12:36 pm
Upon exit from FM, I get the titled error message showing it is trying to create a folder in c:\user\carl\Documents\Fund Manager\autoback
I don't know why this path is being selected since my FM director is set to m:\Fund Manager
schwarcz
Postby Mark » Mon May 15, 2017 12:42 pm
Hi schwarcz,
This path is set at: "Options / General Preferences... / Data". Just make sure it is set to a valid folder where you have write permission.
Postby schwarcz » Mon May 15, 2017 1:11 pm
As I stated, the data directory is m:\Fund Manager. I have full privs in that directory. Why is it not going against that directory?
FM error.pdf
(58.67 KiB) Downloaded 300 times
schwarcz
Postby Mark » Mon May 15, 2017 1:28 pm
The error you're getting is not related to the data directory. It is related to the automatic backup directory, which you can set under ""Options / General Preferences... / Data".
Postby schwarcz » Mon May 15, 2017 1:32 pm
thank you for pointing that out. Problem solved.
schwarcz
