Exported Data Funds.
Postby fhhoule5013 » Wed Aug 02, 2017 12:14 pm
Mark: I am a long time user of your fund, It is the best fund for keeping track of investments.
I have a suggestion, that there be included in the fund a method to convert exported data files(.dat) into file types comparable with commonly used spread sheets. Regards and thanks Frank Houle :)
fhhoule5013
Postby Mark » Wed Aug 02, 2017 2:57 pm
Hi Frank,
You can export any data in your investments to a CSV file, which can then be read into a spreadsheet. For example, see the "File / Export / Prices/Transactions / Generic..." commands. You can also export any report to a CSV file by using "File / Export to CSV..." from within the report window. If there is some other type of data you're looking for, please let me know.
