Unrlz Gain & Unrlz %Gain
Postby divinest » Sat Sep 09, 2017 3:56 pm
I see the following 2 fields available in portfolio editor main page
Are there equivalent fields in the custom report that can be selected?
divinest
Postby Mark » Sat Sep 09, 2017 6:11 pm
Hi divinest,
The Custom report has an equivalent to the "Unrlz Gain" field called:
Tax basis unrealized gain, Assigned Method
It doesn't however have exactly the "Unrlz %Gain", as that %gain is based on the tax unrealized gain/basis. You could write your own user-defined field using the formula:
100.0*Taxunrlzgain_Assigned/Taxbasis_Assigned
This feature requires Professional or Advisor.
In all versions you can get a % Gain based on OOP cost (instead of tax) using the built-in Custom field: %Gain (current)
Postby divinest » Sat Sep 09, 2017 6:23 pm
thanks much Mark. That calculated what i was looking for.
divinest
