How to prevent Win 10 action with Hotkeys
Postby fundman247 » Fri Oct 06, 2017 12:49 pm
I wonder if you can help to prevent Win 10 going to the Microsoft web site help if any Func key or menu item that is on a Func key shortcut.
If one chooses Contents or even Keyboard under the Help menu then the Microsoft web site help opens. If one is not connected to the internet you get the network error page. This happens in other software as well as most software have F1=Help.
Remeber and practise it!!!!!!
fundman247
Postby Mark » Fri Oct 06, 2017 5:40 pm
Hi fundman247,
If you press F1 from within Fund Manager what happens? It should open the local help file for Fund Manager.
Postby fundman247 » Sat Oct 07, 2017 12:30 am
It goes to Microsoft help web page and does not open the help file within FM.
fundman247
Postby Mark » Sat Oct 07, 2017 10:38 am
Hi fundman247,
I'm not sure. It doesn't do that for me under Window 10. Maybe you have some other program intercepting the shortcut keys?
Postby fundman247 » Sat Oct 07, 2017 12:07 pm
I found Win 10 do as per this topic on a forum with FM.
fundman247
Postby Djobydjoba » Sat Oct 07, 2017 3:02 pm
The topic you've found is this one? https://www.howtogeek.com/235351/how-to ... cial-keys/
It's well explained. You can toogle between function keys and special keys with the Fn key or Esc+Fn keys. Your keyboard is probably in the special keys state currently, and not in the function keys state.
Postby fundman247 » Sat Oct 07, 2017 4:34 pm
Thanks a stack for explaining and the link to the whole article about Fn lock.
Regards.
fundman247
