Is this Malware?
Postby Econdoc » Sun Nov 05, 2017 6:48 am
I run Adwcleaner from Malwarebytes weekly. It consistently reports this registry key as a Potentially Unwanted Program (PUP).
PUP.Optional.Legacy, [Key] - HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\App Paths\FM.exe
Does this key belong to Fund Manager? Can I tell AdwCleaner to remove it?
Econdoc
Postby Mark » Sun Nov 05, 2017 9:51 am
Hi Econdoc,
Yes, that belongs to Fund Manager. It is the key that remembers where Fund Manager is installed, so the next time you install a new version, it defaults the setup program to install to the same location. I would not remove it. Maybe you can tell that program it is okay and it should ignore it?
Postby Econdoc » Sun Nov 05, 2017 3:08 pm
Thanks for the info, Mark.
I wish that I could tell the software to ignore that entry, but that does not seem to be an option. (What you get for free? :D ) Anyway, I will be careful to NOT let it delete that entry. That is what I needed to know.
Econdoc
