On the Web/Android gadget...
Postby DavidJ » Mon Nov 06, 2017 9:17 am
what does "suspend while working" mean? What is working in this context?
David.
DavidJ
Postby Mark » Mon Nov 06, 2017 9:49 am
Hi David,
Are you asking about the Android app? The only "Suspend While Working" option I know about is relating to automatic price retrieve inside the main FM program. It is at "Options / Internet Settings... / Automatic Retrieve Frequency... / Suspend While Working". If you press "Help" in that dialog it explains this option as:
When automatic retrieve is turned on this option will prevent a retrieve from happening while you are using Fund Manager. In this case the retrieve will be postponed until you have stopped using Fund Manager. Fund Manager assumes you are not using the program if there has been no activity for a period of 60 seconds. This option is memorized in portfolios.
"Using" Fund Manager means moving the mouse around, typing on the keyboard with the focus on FM, selecting any menu command, etc.
Postby DavidJ » Tue Nov 07, 2017 12:02 am
Got it now, thanks.
Just to clarify, the question was meant to be: whether having the focus on FM alone, without mouse or keyboard activity, would be considered working.
DavidJ
Postby Mark » Tue Nov 07, 2017 7:54 am
Hi DavidJ,
No, just having the input focus on FM is not considered working.
