What is the best way to delete all FM files from my computer and to start all over again?
Should FM be deleted and then downloaded again?
Jim
Start from scratch
Hi Jim,
From within Fund Manager you can use "File / Close Portfolio" and that will close everything. If you want to also remove any data files from your hard drive, you'd have to manually go do that yourself, from within Windows, using File Explorer or something similar to delete the files. The default directory where your data is stored is "My Documents \ Fund Manager". If you already have the current (or desired) version installed, there should be no reason to have to uninstall and re-install it, but you can.
Who is onlineUsers browsing this forum: No registered users and 4 guests |
