List Column Templates
Postby John Lea » Thu Mar 08, 2018 4:45 pm
I am sure I am missing something but I can't get the preferred columns to be consistent. I set a "view" up and save it as a template. Sometime it is there when I call on it but often when I am setting up a different template it over writes another. I am not sure I'm taking the same steps each time and likely that is the problem.
Is there someplace in help that outline the specific steps to take to set up a template and have it stay?
John Lea
Postby Mark » Fri Mar 09, 2018 8:09 am
Hi John Lea,
The instructions are pretty basic, but they are here. Basically, you just right mouse click on the list column header, and use the menu to save or recall a list column template. Column templates are only saved when you save them, and aren't updated otherwise.
Postby John Lea » Fri Mar 09, 2018 10:20 am
Wow. Works like a charm!
I was coming at it from within View:List Columns:Choose.... and kept stepping on myself.
John Lea
