category labels
Postby ebernard » Mon Mar 19, 2018 10:18 am
Hello,
It seems that the user defined cataegory labels are not stored in the mm4 file.
Indeed, when I open a mm4 file from another computer, I have to enter all the unser defined labels again.
Can you confirm or tell me how to store the user defined labels in the mm4 file ?
Emmanuel
ebernard
Postby Mark » Mon Mar 19, 2018 10:22 am
Hi Emmanuel,
They are stored in the registry, not the mm4 file. You can transfer these with a .FMB backup file. Use "File / Backup..." on one computer with the labels you want. Use "File / Restore..." on the other, and make sure to restore the "Global Registry Preferences". For more, see this FAQ:
https://www.fundmanagersoftware.com/newcomputer.html
