Data Not Found
Postby billroot » Sat Apr 14, 2018 5:09 pm
I seem to have a disconnect between my data files and the program files. When I try to open up File Manager it is not finding any of my portfolios or data-as if I am starting all over with a new portfolio setup for the first time
billroot
Postby billroot » Sat Apr 14, 2018 5:36 pm
Have got data and master portfolio 'connected', but now get an error message:
ERROR: Unable to create automatic backup folder: C:\Users\Bill|Documents|Fund Manager/autoback
billroot
Postby Mark » Sat Apr 14, 2018 6:12 pm
Hi billroot,
Go to "Options / General Preferences... / Data" and set your backup folder location to a valid/existing folder where you have write permission. Use the "Browse..." button there.
Postby billroot » Sat Apr 14, 2018 8:53 pm
Ok-Thanks. Seem to be getting this straightened out after integrating with OneDrive. Now for the backup Master Portfolio files, what is used for the 'Open With' dialog box? Thanks
billroot
Postby Mark » Sun Apr 15, 2018 9:09 am
Hi billroot,
To use a Fund Manager backup file with the extension of *.FMB, you do so from within Fund Manager. Use "File / Restore..." and select the *.FMB file you wish to restore from.
