Fund Manager Screen Resolution
Postby divinest » Wed Oct 03, 2018 7:39 pm
Hi Mark, I recently upgraded to 14 inch laptop (display FDH resolution 1920 x 1080 pixel settings) i noticed the Fund manager screen a blurry, do you have any thoughts or suggestion on what is the optimal settings? thanks for your time in advance
divinest
Postby Mark » Thu Oct 04, 2018 8:09 am
Hi divinest,
There are no settings within Fund Manager that would control the blurriness of your screen. One fairly common reason for screen blurriness is if your display resolution of your video driver is not set to the physical resolution of your screen.
Postby fradek » Mon Oct 08, 2018 11:14 am
Hi divinest and Mark,
I had the same problem (blurry characters) on a 15.6" laptop and it's related to High DPI. I solved this by changing Fund Manager program properties as follows:
- Right mouse click the Fund Manager icon on your desktop and select Properties
- Select tab Compatibility
- Select Change High DPI settings
- Check the checkbox Override high DPI scaling behaviour
- Set Scaling performed by: Application
It's not really user-friendly but the text in Fund Manager is sharp again.
fradek
Postby divinest » Tue Oct 09, 2018 4:05 pm
Thanks, that appears to fix the blurry fonts issue.
divinest
