rearranging portfolio hierarchy?
Postby darrell » Mon Oct 22, 2018 7:40 am
Hi -- Say I have existing portfolios A, B and C.
Is there a way, other than exporting all their data and re-importing it, to move B and C to be sub-portfolios of A?
D
darrell
Postby Mark » Mon Oct 22, 2018 9:00 am
Hi darrell,
Yes, you can do this very easily in the Portfolio Editor window. Just drag/drop the sub-portfolios you want to move. To drag/drop B for example, select the parent of B on the left, so you can see B in the right list. Drag B from the right, over onto the desired destination (A) on the left, and drop it. Please see these tutorials for more:
Portfolio Editor Tutorial
Sub-Portfolio Tutorial
Postby darrell » Mon Oct 22, 2018 9:39 am
ah ok thanks -- was missing that clicking on Master Portfolio listed the sub portfolios in the right pane, thanks
darrell
