Category Labels File
Postby codybear » Tue Feb 26, 2019 11:37 am
Under options, I can edit the "Category Labels". Is this stored in a file? Occasionally, I'll bring up FM on a second computer (not concurrently w/ the first) pointing to files on the first computer. Everything works fine except the Category Labels do not match. Yes, I could edit the second computer, but if I could point to the first computer file or copy the file from the first computer, this would be more convenient.
codybear
Postby Mark » Wed Feb 27, 2019 8:52 am
Hi codybear,
Yes, these are stored in the registry normally. If you're running in portable/cloud mode, they are stored in your fmprefs.txt file. If you're transferring between computers, use a *.FMB backup file. This will restore data and preferences as well. You can also choose what to restore, so if you only want to restore preferences, you can do that as well.
