Advisor Version: Clients and Sub-Portfolios.
Postby aviator » Sat Apr 06, 2019 4:39 pm
I took the plunge and upgraded to the advisor version primarily for its ability to calculate user fees.
Here's my problem: I can't subtotal the Management Fees report by client. I have clients assigned to each sub-portfolio using the Client Information screen (I only input first and last name, and used the drop down to assign a sub-portfolio to my client.)
When I run the report, I get a <not assigned> at the bottom of the (non-subtotaled) list of accounts. What am I doing wrong?
Postby Mark » Sat Apr 06, 2019 4:53 pm
Hi aviator,
Could you have a different *.mm4 file open than where you assigned your clients? If you go back to the client list you can verify they are assigned to your current portfolio file.
Postby aviator » Sat Apr 06, 2019 5:11 pm
OK, for some reason a new file called Client List was created but reverted to my original .mm4. Added back my clients -- when I click on the sub-portfolio properties, a client is assigned.
But when I run the report I still get the <not assigned>. What am I doing wrong?
Postby Mark » Sat Apr 06, 2019 5:30 pm
Hi Aviator,
I'm not sure. I'm on vacation now, through next week. Please see if watching thus tutorial on using clients doesn't help
https://youtu.be/Ct6oZHFDY6E
If the problem persists we can do a web meeting when I get back.
Postby aviator » Sat Apr 06, 2019 5:53 pm
The tutorial didn't help much as I already had my hierarchy set up.
I'm frustrated now, but I'll try again later this week. It's got to be something obvious -- all sub-portfolios have a client assigned (am no longer getting <not assigned>) but I just can't get the report to sub-total by client. Weird.
I'll follow up when you're back from vacation. Thanks.
