Restore Question
Postby LungDoc » Sun Apr 14, 2019 2:41 pm
Is is possible to restore the data from just one investment?
I lost historical data on one of my holdings. I'm certain that I have that data in an old backup file, but recent backups no longer have the older historical data that I want. Another question: is is possible to set up a separate portfolio that is not included the the Master Portfolio and would not "see" any other FM data
LungDoc
Postby Mark » Sun Apr 14, 2019 2:47 pm
Hi LungDoc,
Yes, you can restore anything, including just a single investment. Use "File / Restore..." and pick the *.FMB you want to restore from. Select the one investment in the list, and choose the option to only restore selected items (not everything in the backup).
Yes, you can have multiple *.mm4 portfolio files, which are completely independent. A better solution is usually to create another level of hierarchy in your existing *.mm4 portfolio file. So, if you have something like:
Code: Select all
- Master
  - Stuff
create another level, like:
Code: Select all
- New Master
  - Master
    - Stuff
  - New Port Separate from Master
You can do this using the Portfolio Editor. See the sub-portfolio tutorial.
Postby LungDoc » Mon Apr 15, 2019 5:59 am
Thank you for your help (again). DL
LungDoc
