Unlicensed Evaluation?
Postby heidiasst » Thu May 02, 2019 11:21 am
Hey Mark,
How do I return to our previous version after evaluating a newer
version?
Heidi
heidiasst
Postby Mark » Thu May 02, 2019 11:50 am
Hi Heidi,
You can download any older version you are licensed for from here:
https://www.fundmanagersoftware.com/download_old_fm.php
Please keep in mind that if you are downgrading from FM 2018 to FM 2016 you will need to restore your data from a backup made with FM 2016. FM 2018 uses a new file format, which cannot be read by FM 2016.
Postby heidiasst » Fri May 03, 2019 10:43 am
Since my recent back ups were on the new version, I would need to enter everything since I downloaded this version I assume after restoring the older version.
Correct?
heidiasst
Postby Mark » Fri May 03, 2019 10:48 am
Yes that is correct. Any data you entered using the new version would be saved in the new file format.
Postby heidiasst » Fri May 03, 2019 11:44 am
So, since that's not happening how do I purchase this new version?
heidiasst
Postby heidiasst » Fri May 03, 2019 12:50 pm
Disregard, just purchased it.
Thanks Mark
heidiasst
