Yahoo Historical Server
Postby George B » Fri May 03, 2019 11:14 am
Try8ing to retrieve data from the Yahoo Historical server an am not getting anything. I have Quote Module 537 and transaction module 237.
Thanks for the help Mark
George
George B
Postby Mark » Fri May 03, 2019 11:26 am
Hi George,
Can you email or post your price retrieve log? See "Help / Logs / Price Retrieve...".
Postby George B » Sat May 04, 2019 7:50 am
Here is the log.
etrieve Starting
Quote Module Version = 537
Requested Historical Retrieve Dates: 2/8/2019 - 2/8/2019
Requesting: "949763QK5", "ETRN", "WMPXX", "EQM", "NFFFX", "EQT", "N/A", "MINIX", "ICAFX", "LAVYX", "MEIIX", "GILAX", "", "FALIX", "PIGIX", "MEICX", "AICCX", "RICE", "LGLIX", "DWDP", "FHTIX", "LBNYX", "LCEYX", "TRVLX", "SVAIX", "AFICX", "MDIGX", "DOW", "GSSMX", "ive", "LGLCX", "LGLFX", "GASFX", "AAP", "MGICX", "DLN", "HBAN", "GPC", "DOO", "ELD", "VEA", "VNQ", "VWO", "SJNK", "BKLN", "CIU", "SHY", "IEF", "EMB", "IGOV", "LQD", "FLOT", "IJK", "IJJ", "IJS", "IJT", "LAUSX", "TEGBX", "TGCNX", "YAFFX", "PSX", "GSSCX", "IGAAX", "ASBAX", "ABT", "COP", "ANWPX", "CLF", "NEE", "EMR", "CAT", "AIVSX", "NEWFX", "SMCWX", "ANCFX", "IHCAX", "GSQBX", "AGTHX", "CWGIX", "AMECX", "AWSHX", "AFTEX", "AMHIX", "MSZ", "ABCSX", "AEPCX", "STCSX", "FTCHX", "JAMRX", "CMUCX", "BMECX", "FDSXX", "VFINX"
WARNING: Server used but did not update any prices: (YAHOO-HISTORICAL)
Retrieving from server: (FINRA)
Requesting: "M8450514953766", "M6774584564699", "40429XUJ3"
Updating Data...
1 -> M8450514953766: 103.030000 on 5/3/2019
Retrieving from server: (REUTERS)
Requesting: "RMP"
Updating Data...
1 -> RMP: 0.010000 on 5/3/2019
Updated 2 Prices
George B
Postby Mark » Sat May 04, 2019 7:57 am
Hi George B,
I test retrieved ETRN from Yahoo Historical for 2/8/19 and it retrieved okay from here. If you right mouse click on ETRN and retrieve selected historical prices for only this one investment, does that work? If not, can you post the "detailed" version of the price retrieve log after retrieving only this one historical quote?
Postby George B » Sat May 04, 2019 8:42 am
The one you tested worked for me but SVAIX does not work.
George B
Postby George B » Sat May 04, 2019 8:50 am
Retrieve Starting
Requesting: "SVAIX"
George B
Postby George B » Sat May 04, 2019 9:14 am
Further testing.
Using SVAIX
Retrieve date range 2/7/19 to 2/9/19 I get 2/7 & 2/8, 2/9 is a Saturday.
Retrieve date range 2/7/19 to 2/8/19 I only get 2/7/19.
George B
Postby Mark » Sat May 04, 2019 10:08 am
Hi George B,
Can you send me the "detailed" price retrieve log for this case (2/7 - 2/8 SVAIX)?
What time zone are you located in?
Postby George B » Sat May 04, 2019 12:44 pm
Mark, I do not find the topic "logs / price retrieve" in help.
I am in the Eastern Time Zone.
George B
Postby Mark » Sat May 04, 2019 4:51 pm
Hi George B,
The detailed log is right next to the regular price retrieve log. It is under the top level "Help" menu and then "Logs". It isn't in the online help.
Postby George B » Sun May 05, 2019 7:57 am
I am opening help in the software and do not see anything about logs. Thanks for your assistance,
George B
Postby aviator » Sun May 05, 2019 8:22 am
It's there. From the topmost menu (File, Edit, View... Help), click on Help. The third menu option down is Logs.
Postby Djobydjoba » Sun May 05, 2019 8:32 am
I think the Logs entry menu is only available since Fund Manager 2018, and for prior versions the logs can be found here : C:\Users\Namexxxx\AppData\Roaming\Fund Manager\
Postby George B » Sun May 05, 2019 8:44 am
When I click on "Help" my options are "Contents; Help on Portfolio Editor; Fund Manager on the Web; About"
George B
Postby George B » Sun May 05, 2019 8:47 am
Djobydjoba wrote:Hi,
This explains why I am not seeing what Mark referring to. I am on an older vision of the software.
George B
Next
