Can't Upload Mobile/Web Holdings Automatically
Postby osinv » Fri May 10, 2019 10:32 am
In the Options->Mobile/Web Access->Preferences I have marked the option "Automatically Update on Program Exit". However I have noticed that this is not executed automatically, hence I end up pushing the upload manually.
Is there something I could do/check to see if I can make it work automatically?
Oscar
osinv
Postby Mark » Fri May 10, 2019 11:32 am
Hi Oscar,
It will only do the upload if you had any change of data. Could this be the reason you're not seeing it upload automatically?
Postby osinv » Fri May 10, 2019 2:14 pm
Thank you Mark, actually it was happening when the portfolio value had changed. Anyway, it is working fine now, so I'll report back if it fails to do it again.
osinv
