restore failed
Postby alpappy » Wed May 15, 2019 4:50 pm
Hi mark I cannot restore from backup I get access denied then message thst csnnot find the user file I created a new location now it restores some but the skips most of the investments not found I have used two backup sources same tresult t hanks alan
alpappy
Postby Mark » Wed May 15, 2019 5:04 pm
Hi alan,
It is likely you are trying to restore to an "original location" that doesn't exist. Try setting your data location (File / File Operations / Set Data Location...), so that all files are in a single folder, and then do another backup, and then restore from this backup, and restore to a "Specified" folder that exists, and where you have write access.
Postby alpappy » Wed May 15, 2019 5:37 pm
Thanks that worked data was in multiple locations how did that happen
alpappy
Postby Mark » Wed May 15, 2019 5:39 pm
Hi alpappy,
I can't say for sure how it happened, but when you create new investments (whether manually, importing, or retrieving) you specify where they are saved. It is usually best to just always save everything to the same folder.
