I am not doing something right... HELP
Postby wizard348 » Fri Sep 27, 2019 3:00 pm
I was having a problem syncing on Drop Box. So I moved to One Drive and no more problem.
But when I ask FM to retrieve Asset type and Sectors, it was changing everything to unclassified. I changed to "If retrieve fails: Leave unchanged, so everything is always unchanged. The ETF's that it changed to unchanged, it will not change back.
I tried it on Drop Box, and it does the same thing.
On a thumb drive is toooooo sllllooooowwww.
wizard348
Postby Mark » Fri Sep 27, 2019 4:32 pm
Hi wizard348,
Do you have the latest quote module? See "Help / FM on the Web / Check for Updates...".
If you create a new investment with the symbol VTSAX and set it to a No Load Mutual Fund, and then retrieve asset types for that, does it work? If not, please send me the log from "Help / Logs / Asset Type Retrieve...".
Postby wizard348 » Fri Oct 04, 2019 3:19 pm
I do not have a file "help/logs/asset type retrieve"....
wizard348
Postby Mark » Fri Oct 04, 2019 4:07 pm
Hi wizard348,
What version of FM are you using?
What quote module # are you using?
Did you try retrieving VTSAX as a test? Did it work? Do you receive any error messages? The log file is named assettoplog.txt.
