Print question
Postby Mike » Thu Jan 15, 2009 3:54 pm
Is there a way to set up page breaks between sub-portfolios when printing reports? Now I have to change settings to print each client's reports. It's no big deal but it would be nice if this could be done.
Mike
Postby Mark » Thu Jan 15, 2009 4:08 pm
Hi Mike,
You can't insert page breaks there, but you can use the "Batch" printing feature to accomplish this. This is a feature in the Advisor version. It works like this:
1) Define all your clients and assign them to a sub-portfolio under "Edit / Client List...".
2) Create any reports and/or graphs you want to print for all your clients. It doesn't matter what sub-portfolio you initially create them for.
3) Use "File / Batch Print..." and select what clients you'd like to print these open graphs/reports for. Since you've defined what sub-portfolio each client owns, the reports/graphs will be generated for that sub-portfolio before being printed. Also, you can set the starting page number, and have the page numbers be contiguous across multiple reports/graphs.
