Portfolio Editor window Background Color
Hi Mark, Is there a way to change the background color to dark background. With the recent themes in windows to have dark/light - wanted to see if FM can be configured to either match the windows theme or custom config the background color. If not available may be something for future releases. Thanks!
Hi divinest,
The Portfolio Editor uses the default colors, based on your Windows color theme/settings. If you change it in Windows, this should apply to the Portfolio Editor as well.
Hi divinest,
I just tested this from here, using Windows 7. It worked as expected. If you go here: Control Panel\Appearance and Personalization\Personalization you can choose from different "Themes". If you pick one with a black background, and then start FM you should see the background of the Portfolio Editor being black. I tested it with a theme of "High Contrast Black". I'm not sure if you'll have the same named theme, but the idea is to pick one where all the backgrounds are black, or whatever you want.
Who is onlineUsers browsing this forum: No registered users and 17 guests |
