2020.16.2 Install failed
Postby the4cooks » Thu Dec 26, 2019 4:20 pm
Hello,
I have a brand new HP laptop and I downloaded ver 2020.16.2. The install failed and stopped
when extracting a file with msg "extract error writing to file fb.dat." Never had any problems
before downloading and installing. What is the problem?
thanks, Rich
the4cooks
Postby Mark » Fri Dec 27, 2019 9:21 am
Hi Rich,
It sounds like there is a permission problem with the sample data files. If you haven't modified them for your own use, just delete the "Samples" folder at:
C:\Users\<username>\Documents\Fund Manager\Samples
and then try installing again. The install program will replace that Samples folder.
Postby the4cooks » Fri Dec 27, 2019 12:01 pm
I finally installed 2016.16.2. I kept getting extract errors every time I tried to install. Each time I ran the install I got an extract error further down to the next file. This occured about 10 times. Finally got through to the end and installation was complete. Then I ran a backup old/restore new to my new laptop and everything is looking OK so far. Really don't know know what caused the problem.
Rich
the4cooks
