Some investments not stored where expected
Postby senior » Wed Feb 26, 2020 5:31 am
I found out that the three recent new investments are stored in the root of the HD and not with the rest of the other DAT files in the My_Data folder of FM. How do I get them into the proper folder without losing the content ? I am using FM 2020 Personal 2020.16.3.100 serial 95786.
Greetings,
senior
senior
Postby Mark » Wed Feb 26, 2020 9:33 am
Hi senior,
Use "File / File Operations / Set Data Location...", and it will move everything into the folder you select.
Postby senior » Wed Feb 26, 2020 10:08 pm
thanks for your help, it worked fine. One question remains: may I erase the DAT files in the "unwanted" folder or is there a necessary link remaining?
Greetings,
senior
senior
Postby Mark » Thu Feb 27, 2020 10:40 am
Hi senior,
Yes, after you've moved the files, you can safely delete the files from the original location.
Postby senior » Thu Feb 27, 2020 10:05 pm
I'm happy that all went so smoothly, I really appreciate FM.
Thanks and have a nice weekend,
senior
senior
