I discovered in my Users directory a file: NTUSER. The File Explorer Properties says that the Type of file is: Fund Manager Investment (.DAT). What it is?
Thanks nebfinfm
NTUSER
Hi nebfinfm,
In Windows, FM is associated with the filename extension .DAT. This same extension can also be used by other programs, but if you have an extension associated, then this will be shown by Windows. It does not necessarily mean all .DAT files were created by Fund Manager. That is the case here. That file you mentioned is a Windows file, and not a FM file.
Hello Mark, thanks for quick reply.
Do you have an idea what is this file? FYI I'm storing / backing FM data to different back-up drive. Is it possible that Windows is backing / creating this file without my knowledge? I don't like to have my data stored somewhere without my knowledge. Can I erase this NTUSER file? Thanks nebfinfm
Hi nebfinfm,
A quick Google search for "what is the NTUSER.dat file in Windows" will tell you a lot. I wouldn't delete it. It is part of Windows, and is not related in any way to your FM data.
Hi Mark, thanks for advice, I found "Don't Delete the NTUSER.dat file..."
FYI I thought that NTUSER.dat file is associated with FundManager becouse the icon was a classical FM icon and the properties also said it is a FM file. Evidently in my computer the .dat extension is associated only with a FM application. Thanks nebfinfm
Who is onlineUsers browsing this forum: No registered users and 12 guests |
