Hello Mark,
I am sorry to disturb you with so many questions.
I’m very interested in FM but I have to do everything by manually both inserting transactions
and import prices with files and therefore I want to understand if it is feasible.
1. If a create a new investment i.e. named Fund and “symbol” “FUNDxxx” and then insert transactions and historical prices on the days of purchase and afterwards I need to change the symbol due to different data provider what happens? I want to understand if there is a single database of prices for every single investment and how are they related to transactions.
For example if I buy 100 shares on the 1st of February 2020 with symbol FUNDxxx at 1 $ and I do not upgrade its price. Then if I want to import a long historical file of prices of the fund that needs a different symbol “FUNDzzz” with only close that goes back to 2015 (although the security is always the same) and I discover the new file has a close of $ 1.05 on the 1st of February.
Which price will be displayed on the 1st of February? And my transaction purchase? Can they be different?
2. Is it correct to say that if I use an Advisor version I can restore a Pro backup? Or if I saved a backup of the Pro version I cannot restore it in an advisor version of software? So how restore from backup relate to each other according to different versions of the software (I‘m interested and in doubt only between the Pro and Advisor versions) ?
3. Can I have an evaluation period for both Pro and Advisor version on 2 different Pcs at the same time ?
Thanks in advance for your answers
Arrow
