error 12029
Postby ericr » Mon Feb 16, 2009 8:56 pm
My Fund Manager (8.7 on Windows Vista) just started showing
Winlet Error Code 12029 Message: A connection with the server could not be established
when I try to update prices. I get the same message if I try to check for updates.
I understand this might have something to with the firewall. Mine didn't have Fund Manager listed as an exception so I added it, but I still get the same error message.
I had to do a system restore recently. Could that have anything to with the problem? Any other ideas?
Eric
ericr
Postby Mark » Tue Feb 17, 2009 8:13 am
Hi Eric,
That error message does usually indicate that Fund Manager is not able to access the internet because it is being blocked by a firewall program. I would double check that you've added the exception okay into your firewall program, and maybe re-start your computer. Yes, a system restore may have had some impact on the settings of your firewall.
