Import Multiple SubFolio Accounts
Postby csulbaran » Mon Aug 24, 2020 1:38 pm
Is there a way to import, from a CSV, multiple accounts with different portfolio hierarchies?
For example I'd like to import something like this:
Portfolio Hierarchy_________________Account Number________Portfolio Name
Top Level/Client 1/Client Account 1_____A12301 _________________Portfolio 1
Top Level/Client 2/Client Account 1_____A45601 _________________Portfolio 1
Top Level/Client 2/Client Account 1_____A45602 _________________Portfolio 2
Top Level/Client 2/Client Account 1_____A45603 _________________ Portfolio 3
If not what's the best way to do this for over 350+ new portfolio/sub-folios?
csulbaran
Postby Mark » Mon Aug 24, 2020 2:32 pm
Hi csulbaran,
You can't import only sub-portfolios. However, if you import transactions or positions assigned to non-existent sub-portfolios (based on account number), these sub-portfolio will be created for you (along with the investments and the transactions). Usually this is how you get started. Import the actual transactions/positions, and all the sub-portfolios will be created automatically. The sub-portfolios won't have any hierarchy, but you can arrange them manually after the import.
If you want to do this with a CSV file, I've attached a sample to this post. Use the "File / Import / Transactions / Generic..." command with the format string:
ACCT,TRAN,SYMB,ANUM,BNUM,CNUM,MM/DD/YY
for the attached sample.
imptest.csv
Sample Generic Transaction Import CSV
(72 Bytes) Downloaded 268 times
