Just for Fund Manager Info
I set a Trailing Alert using the Edit/Pull Down/Trailing Alert. Then when I want to edit the trailing alert I have set, I Right Click on the Alert Line and a large menu pops down for me. At the very top of this large menu, the Edit Alert and Delete Alert appears twice. They appear to do the same thing.
Hi wizard348,
What version are you using? See "Help / About...". Can you tell me specifically what window you're in? It sounds like a Graph window. If so, what graph type are you displaying when you see this issue?
I am using the Pro Version 2020.16.4.100.
The graph is a MA Overlay: Price+Distribution. The alert is a Trailing Stop Loss Alert. The alert shows up on my graph as purple in color. I want to change the Percentage in the alert from 8% to 10%. I place my mouse on the purple line and right-click. That brings up a large menu to the right of the screen. At the very top of that menu, there is an option to Edit Alert and another option to Delete Alert. Those two options appear twice. I found the problem and fix it. I had two alerts. ![]()
Hi wizard348,
Glad you found it... That was a tricky one.
Who is onlineUsers browsing this forum: No registered users and 14 guests |
