Auto-sizing reports
Postby Robert A » Wed Dec 30, 2020 11:37 am
My laptop has a somewhat unusual resolution of 16:10. Reports always run off the screen to the right, I'm guessing because FM is expecting 16:9.
Is there a way to get the default Portfolio Performance report to fit my screen, without scrolling horizontally in order to see the yield column?
Thank you
Robert A
Postby Mark » Wed Dec 30, 2020 11:41 am
Hi Robert A,
The size of the window can be whatever you want. Maybe your report is too wide to fit? If so, you can use a smaller font, or narrower column widths, or eliminate some columns you don't care about.
