>Change .WAV sound
Postby rhakim » Tue Jan 05, 2021 6:53 am
Is there a way I can change the sound I hear when I attempt to leave an open dialog window that needs information.
For Example: if you go to File/New Investment ....... a dialog window opens
the sound I want to change is the one you hear when you attempt to leave this screen without clicking on the ---- OK ---- Cancel ------ Help ----- buttons or by clicking on X.
rhakim
Postby Mark » Tue Jan 05, 2021 9:06 am
Hi rhakim,
These sounds are configured in Windows. These are system sounds. If you go into Window's Settings, and search for "Sounds" you can find "Change System Sounds". I'm not sure which sound is assigned to this case you describe, but you can probably determine with some experimentation.
