advisor help
Postby gerhardps » Tue Mar 10, 2009 8:11 am
I've been using the pro version for about 2 years now and love it. I was thinking of upgrading to the advisor version, and was wondering if there was any docs explaining how the added features work. I have downloaded a trial version to test it, but can not see any difference in the menus etc. How do you enter different clients info?
thanks in advance
gerhardps
Postby Mark » Tue Mar 10, 2009 2:44 pm
Hi gerhardps,
We don't have a specific document explaining just the differences (probably would be a good idea...), but there is a high level summary of the differences in our version comparison table:
http://www.fundmanagersoftware.com/versions.html
I can quickly point out where you can access some of these features.
- "Edit / Client List...". You use this dialog to define your clients, enter their contact info, notes, etc. You also assign a client to a particular sub-portfolio here. This information is used when batch printing, so you can for example ask to print a certain set of reports/graphs for all your clients at once. Instead of you having to manually go in and set up each report/graph for each client, you just set the report/graph up once, and when batch printing it automatically changes the sub-portfolio to that client's assigned sub-portfolio. Client information can also be mail merged into report titles and sub-titles. (Options / Report Headers...)
- "File / Batch Print..."
- "File / Send By Email...". Send graphs/reports to your clients by email.
- From within a report window "Edit / Copy Picture", or from within a graph window "Edit / Copy to Clipboard". This command copies a re-sizable image to the clipboard that you can paste into some other document, like if you want to put some wrapping verbage or put multiple graphs/reports on a single page.
- All of the broker/dealer interfaces are under "File / Import"
- You'll also notice differences in the "Report Settings" dialog in some cases. For example, if you turn on sub-totaling you'll see the option "Limit Hierarchy to X Levels". This can be useful if you just want to show the top level summaries, but not go all the way down the sub-portfolio hierarchy. You will also see the option "Hide Totals In Footer". This can be used to put an index at the same level as a client's portfolio in a report, but not report on the total of the index plus the client portfolio.
- Report disclaimers can be set from within any report window under "Options / Report Preferences... / Disclaimer".
