Merge Portfolios into new Master
Postby andyg » Sun Feb 28, 2021 11:44 am
How do I merge two portfolios into a new master porfolio so that each of the two existing portfolios is now its own sub-portfolio? I want to continue to track the two portfolios (wife and I) separately but at the same time be able to generate reports on both. Thanks...
andyg
Postby Mark » Sun Feb 28, 2021 12:02 pm
Hi andyg,
Do you mean you have two *.mm4 files now, and want to put them into a single *.mm4 file as sub-portfolios? If so, just use copy/paste. Open up the first *.mm4 file, select the sub-portfolio, and use "Edit / Copy". Open up the desired new *.mm4 file, and use "Edit / Paste". Repeat for the other one. This is demonstrated in this old tutorial:
https://www.fundmanagersoftware.com/tut ... video.html
Postby andyg » Sun Mar 07, 2021 8:49 am
Thank you, Mark. That was actually too easy.
andyg
