Move data files
Postby cbenenax » Thu Mar 04, 2021 10:15 am
Is is possible to change the directory in which the data files for a subportfolio are stored?
cbenenax
Postby Mark » Thu Mar 04, 2021 10:17 am
Yes. You can do it 1 investment at a time, or the easier way is "File / File Operations / Set Data Location...".
Postby cbenenax » Thu Mar 04, 2021 10:29 am
In Portfolio Editor I highlighted one subportfolio and selected File > File Operations > Set Data Location:
This seems to change the base location of all Subportfolios. Can I change just the subdirectory in which one subportfolio's files are stored?
cbenenax
Postby Mark » Thu Mar 04, 2021 11:01 am
No. This command will move all your data files, not just one for a particular sub-portfolio. Usually this is the best way to store your data (all files in a single folder). It works a lot better if you need to move your data to another computer.
